Доброго дня! В общем ничего не предвещало беды, но в какой-то момент начались непонятные проблемы) Список прилагается:
1. Утром после стоянки задняя ось была в низу. Завел машину. Всё поднялось в нормальное положение, но как только насос отключается, задняя ось опускается.
2. Диагностика показала следующие ошибки:
State of the ECU: BSI
F5FF : Unexpected re-initialisation fault coming from the BSI.
Characterisation : not characterised
ABRASR : Anti-lock Braking System (ABS) or Electronic Stability Program (ESP)
U1217 : Fault: no communication with Built-in Hydraulics Interface.
Characterisation : Data invalid
Status : Temporary
Variables associated with the fault
vehicle speed : 0 kph
Front LH wheel speed : 0 kph
Front RH wheel speed : 0 kph
Rear LH wheel speed : 0 kph
Rear RH wheel speed : 0 kph
EBA regulation : deactivated
EBD regulation : deactivated
Anti-slip regulation with action on brakes (BASR) : deactivated
Anti-Slip with action on engine torque disconnected (ASR/ESR) : deactivated
Anti-engine brake regulation (MSR) : deactivated
Anti-Slip regulation with action on engine torque (ASR) : deactivated
Electronic Stability Program (ESP) regulation : deactivated
ABS regulation : deactivated
Recirculation pump activated : No
Electric parking brake status : Off
Status of the "assisted holding" function : No holding
Braking status : No braking in progress
Yaw angle speed : 000 °/s
transverse acceleration : -00.2 m/s²
Steering wheel angle : 27.3 degrees
Distance travelled since last time ignition switched on : 0.0 km
supply voltage : 13.7 V
Braking pressure : 00.0 bars
status of the ECU : Main
longitudinal acceleration : 0.00 m/s²
Clutch pedal sensor voltage : Value invalid V
BOITEVIT : automatic gearbox or controlled manual gearbox
U1208 : Signal error transmitted by the engine management ECU over the CAN network
Characterisation : incorrect value received
CORPRO : Dynamic headlamp height adjuster
U1217 : Dialogue with the suspension ECU
Status : intermittent
SUSPVAR : Electronically managed suspension
State of the ECU: SUSPENSION_ECOTECH
Reference 1 : 758278
Reference 2 :
Faults present : 4
U1118 : fault: absence of communication with the Built-in Systems Interface
Characterisation : No signal
U2118 : Triggering (height adjustment receipt anomaly)
Characterisation : Not characterised
U2005 : triggering (vehicle speed receipt anomaly)
Status : Permanent fault
DSG : Under-inflation detection
U1213 : fault in the vehicle speed information received by the CAN from the ABS or ESP ECU
3. Была ошибка связи с задним датчиком положения, датчик и тягу заменил. Ошибка не появляется.
4. И финальный результат этого всего: Перед работает как и должен, зад не поднимается. При тесте исполнительных механизмов, зад приподнимается на пару сантиметров и падает обратно.
Что делать с этим букетом? Последняя надежда на форум)
Status : Temporary
Reference 2 :
Faults present : 4
