Непонятные проблемы с гидроподвеской!
Evan
9 Июн 2018
Доброго дня! В общем ничего не предвещало беды, но в какой-то момент начались непонятные проблемы) Список прилагается:
1. Утром после стоянки задняя ось была в низу. Завел машину. Всё поднялось в нормальное положение, но как только насос отключается, задняя ось опускается.
2. Диагностика показала следующие ошибки:
State of the ECU: BSI
F5FF : Unexpected re-initialisation fault coming from the BSI.
Characterisation : not characterised
ABRASR : Anti-lock Braking System (ABS) or Electronic Stability Program (ESP)
U1217 : Fault: no communication with Built-in Hydraulics Interface.
Characterisation : Data invalid
Status : Temporary
Variables associated with the fault
vehicle speed : 0 kph
Front LH wheel speed : 0 kph
Front RH wheel speed : 0 kph
Rear LH wheel speed : 0 kph
Rear RH wheel speed : 0 kph
EBA regulation : deactivated
EBD regulation : deactivated
Anti-slip regulation with action on brakes (BASR) : deactivated
Anti-Slip with action on engine torque disconnected (ASR/ESR) : deactivated
Anti-engine brake regulation (MSR) : deactivated
Anti-Slip regulation with action on engine torque (ASR) : deactivated
Electronic Stability Program (ESP) regulation : deactivated
ABS regulation : deactivated
Recirculation pump activated : No
Electric parking brake status : Off
Status of the "assisted holding" function : No holding
Braking status : No braking in progress
Yaw angle speed : 000 °/s
transverse acceleration : -00.2 m/s²
Steering wheel angle : 27.3 degrees
Distance travelled since last time ignition switched on : 0.0 km
supply voltage : 13.7 V
Braking pressure : 00.0 bars
status of the ECU : Main
longitudinal acceleration : 0.00 m/s²
Clutch pedal sensor voltage : Value invalid V
BOITEVIT : automatic gearbox or controlled manual gearbox
U1208 : Signal error transmitted by the engine management ECU over the CAN network
Characterisation : incorrect value received
CORPRO : Dynamic headlamp height adjuster
U1217 : Dialogue with the suspension ECU
Status : intermittent
SUSPVAR : Electronically managed suspension
State of the ECU: SUSPENSION_ECOTECH
Reference 1 : 758278
Reference 2 :
Faults present : 4
U1118 : fault: absence of communication with the Built-in Systems Interface
Characterisation : No signal
U2118 : Triggering (height adjustment receipt anomaly)
Characterisation : Not characterised
U2005 : triggering (vehicle speed receipt anomaly)
Status : Permanent fault
DSG : Under-inflation detection
U1213 : fault in the vehicle speed information received by the CAN from the ABS or ESP ECU
3. Была ошибка связи с задним датчиком положения, датчик и тягу заменил. Ошибка не появляется.
4. И финальный результат этого всего: Перед работает как и должен, зад не поднимается. При тесте исполнительных механизмов, зад приподнимается на пару сантиметров и падает обратно.
Что делать с этим букетом? Последняя надежда на форум)
Igor888
Или задний регулятор жесткости или клапан опускания зада в блоке насоса. Быстрее всего первое.
Я бы постучал по регулятору для начала, вдруг поможет.
Потом отсоединил бы трубку сброса ЛДС (обратку) от регулятора. Если при опускании зада из этой трубки течет ЛДС- значит регулятор, если нет-клапан основного блока.[DOUBLEPOST=1557245183,1557243196][/DOUBLEPOST]https://www.drive2.ru/l/525237805173965686/
https://citroen-c5.ru/threads/Рывком-поднимается-задняя-часть-автомобиля.5617/#post-109648
https://citroens-club.ru/topic/61621-регулятор-жесткости-hydractive-3/
Xitro
28 Апр 2020
Коллеги, вот тоже в этой теме отмечусь. В багажнике универсала С5 есть кнопка подъема/опускания. Изучая её назначение = понажимал на неё и не понял она поднимает только зад или и перед тоже ?
Плюсом не понял возвращает ли авто после нажимания на эту кнопку подвеску во 2-е положение или так и остается на том уровне на каком понажимал ?
Чтот ощущение что после её нажимания чуть жестче стало ездить. Кто подскажет ?
Гагарин
7 Ноя 2015
если не реагирует плохо! При покупке не проверил? срочно подключай лексию и считывай ошибки!
Xitro
28 Апр 2020
кто не реагирует ? я где то написал что что-то не реагирует ? и ошибок нет никаких.
повторю вопросы?
1) кнопка в багажнике поднимает только зад или перед тоже ?
2) после поднятия/опускания подвеска сама возвращается в 2-е положение ?
Logos
3 Дек 2011
Эта кнопка опускает зад для облегчения погрузки тяжестей в багажник. После закрывания крышки багажника машина сама поднимет зад на уровень до опускания. Можно и вручную поднять зад этой же кнопкой, при закрытии багажника высота зада будет всё равно скорректирована.
